Export!
DIY Member
I'm trying to remove obstructions from the ceiling area to finish my basement. I have some galv supply pipes that go up to the 2nd floor and I cannot replace them without major surgery. They currently transition to copper in the basement.
Problem is, they extend down past the floor joists and mess with my proposed ceiling. They are close to a floor joist and I'm fairly certain I will not be able to re-thread them if I cut them up closer to the floorboards. Is there some type of reliable transition to get to copper without threads? I'm guessing it would have to be a compression fitting but the porous, somewhat irregular surface of old galv pipes leaves me wondering if this could work.
What can I do if I want to shorten the lines and cannot re-thread?
Thanks for any help.
