Out here the inspectors don't allow any flat vents. Although, the fact that your flat vent is 3" helps to keep an air flow in it, even if the drain backed up and some waste was left in the vent section. To vent it to code, you can put the 3" x 2" combo(tee) in the line before the new 3" wye (wet side) and run it to the wall on a 45 degree angle, then vertically up the wall.
Helpful Plumbing Hints for Residential Construction by Bert Polk Plumbing Inspector Lincoln County
