Results 1 to 5 of 5
Thread: shallow well jet pump mystery
    DIY Junior Member peterng's Avatar
    Oct 2009
    Woodlands, NB
    Default shallow well jet pump mystery
    Good day, bought all I got done tonight was had a beer. That went well.
    I don`t know much, but here`s what I can see.
    Pump pressure guage reads 40psi. I took the primer cap off, full of water, no pressure. No water coming out of pump and pump not running. Lots of power. I cleaned the contacts. Going down now to see if the tubing to the pressure switch is plugged. Last year I adjusted the pressure switch to shut off around 40psi, though it was set a little higher but can`t remember.
    Thing is, there`s no pressure, pressure guages known to go bad are theyÉ
    Can I test to see if the impeller is spinning freely without dissasembling the pumpÉ
    Diamond 1 1é2hp pump model 313501. It was in the house when we bought it. Age unknown, at least 5 years old.
    Pete
    Default water
    IF the pressure gauge reads 40 psi and there is no water, that might be the first indication that something is not working right. Remove the pressure gauge. IF it stays at 40 it is defective, if it drops to zero, then the pipe to it, and probably the switch, is clogged.
    Quote Originally Posted by peterng View Post
    If you get the pump to run, things might improve.
    There may be a blockage in the line and its fittings to the pressure switch.
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    How deep is your well?
    Previous member
    Jul 2009
    North of the Mason dixon Line
    bypass the pressure switch and see if the pump runs
