Results 1 to 5 of 5
Thread: Honeywell RTH7000 Thermostat
    DIY Junior Member
    Oct 2009
    LaFolette Tn
    Default Honeywell RTH7000 Thermostat
    I have purchased a new programable thermostat and am having concerns with the drop down period. I mean. the amount of temperature it should drop before kicking back on. I,m thinking 2 or 3 degrees. Currently does not drop at all. Kicks back on before the room temp drops. Help please!
    Previous member
    Jul 2009
    North of the Mason dixon Line
    you can set that to whatever you want.
    Many of the electronic thermostats do this. You'd have to read the manual carefully to see if it is adjustable. Make sure that you program it to the type of heating system you have (such as furnace, electric, boiler, etc.). They use this information to determine a minimum off time to help keep things from short-cycling.
    DIY Junior Member
    Oct 2009
    LaFolette Tn
    Thanks Stupid
    Plumber jimbo's Avatar
    Couple of things: Don't know if this is your exact model, but check the heat cycle rate setting, function 0240, page 20. http://customer.honeywell.com/TechLi.../69-1900EF.pdf
    Also, the literature describes this model as having this feature: Precise comfort control keeps temperature within 1F of the level you set
