Measure carefully!
You could make an alignment jig out of a piece of ply with a half-circle hole to use as a gauge...butt one end and side up against the studs. Temporarily set it underneath the pan where you want it to sit, then draw a circle on the ply through the hole in the receptor, then cut for your template. Well, you could probably use a sheet of cardboard or heavy paper as well.
You don't want sideways pressure on the pipe and to work properly, it needs to be plumb as well.
