Hi,
As I was trying to install the new shower base in the basement i drilled around the rough-in 1-1/2" pipe then cut the concrete by using a chisel.
When the area was exposed, I found that I drilled into the horizontal pipe as shown in the picture.
IS there a way to plug/repair/patch the hole (approx. 1/4") other than cut more concrete and cut and replace the whole things there?
