In CA you'd have to check the specs to make sure it's ADA compliant to use it for that application. As for the durability, it may be questionable because the Duravit has only two bolts to hang the toilet, where as the typical wall mount toilet has four hanger bolts. Also, the Geberit bolts are smaller diameter than the traditional bolts (Geberit~3/8 bolts; traditional ~ 5/8 bolts).
