Results 1 to 7 of 7
Thread: Price Pfister Madness
    DIY Senior Member Kiko's Avatar
    Jul 2009
    Royal Oak, Michigan
    Default Price Pfister Madness
    My parents' PF kitchen faucet with pullout sprayer was hammering all the time and, finally, the flow was stopped all together. By process of elimination, I isolated the problem to where the sprayer hose was connected to the valve body. It was a bear to get to because of the tiny space under there, but I managed to disconnect the hose. There was some silly, stupid flow restricter mechanism with a small spring in the sprayer hose, which I removed with an o-ring puller. That solved the problem.
    Why in the hell would they need to put a restricter in there, especially one that obviously will fail in a short time period? If someone wants to use less water, all they have to do is not turn on the faucet all the way.
    It's also a check valve so water can only go one direction. They are code but they do mess with the flow at times.
    Default device
    It is NOT a flow restrictor, it is a backflow device to protect your water system. It is required for ANY device with a hose that could be left underwater, such as dropped into a sink full of water. Handheld shower units are supposed to have them also, although few are actually installed with them.
    Jul 2009
    Royal Oak, Michigan
    I guess you plumbers must love this device, because you can come by and charge $200 to remove it when it inevitably fails.
    I smell a conspiracy.
    Dec 2005
    SW Florida
    Quote Originally Posted by Kiko View Post
    This "conspiracy" is based on fact more than other conspiracies.
    http://www.watts.com/pdf/F-sbn.pdf
    Matt
    Enjoying life in SW Florida
    Jul 2009
    Royal Oak, Michigan
    I agree that back flow is dangerous, but why not design a check valve that will last more than a few months? This cheap piece of plastic and spring looked like it came out of a Cracker Jack box.
    Default valve
    MIne has been installed for 10 years and has not had any problem. Maybe you are just hard on "crackerjack" parts.
