Results 1 to 8 of 8
Thread: Watts 800M4QT blowout fitting
    DIY Junior Member
    Oct 2009
    Castle Rock, CO
    Default Watts 800M4QT blowout fitting
    Ok, you can make not only my day, but my entire year here if you answer this.
    I am looking for the proper fitting to connect to a Watts 800M4QT to standard 1/4" air compressor fitting.
    I'm trying to blow out my sprinkler system and the test cocks included on this unit are of such a size that nobody has the parts to hook an air compressor up to it.
    I need help finding the right parts!!
    Thanks in advance,
    Scott
    Aug 2009
    South*East
    The test cock is 1/4". Just screw your fitting in to the test cock. Where the test cock connects to the device it is 1/8".
    John
    Likely the best fitting to start with is a 1/4" street elbow. You can go from there by just screwing nipples, adapters, etc hand tight.
    DIY Junior Member
    Oct 2009
    Castle Rock, CO
    I don't believe any of those sizes are correct.
    I could find nothing standard to fit it at home depot.
    It took 3-4 adaptors to get it to convert, but they don't stay together ... and when I hand tightened it ... the inner piece got stuck in the backflow part and it took an hour to get it back out with vise grips.
    They must be a solution which is a single fitting, right?
    I can't image that jerry rigging this is the correct answer, is it?
    Why do they put these useless test cocks on there, when they only thing I (as the homeowner) needs to do is blow the systerm out once per year ?!
    When I had a febco backflow, I could just insert a standard fitting and that was it. But with the watts its some idiotic 3/8 with different threads or something ...
    DIY Junior Member
    Oct 2009
    Castle Rock, CO
    John, I'll have to check and see if mine really is 1/8 to 1/4 ... I see it shows thats on the website.
    What is a 1/4" street elbow?
    There is a part which the stores carry to blow out these things and I know that one doesn't fit mine.
    A street elbow is an elbow that has male threads on one end and female on the other.
    DIY Junior Member
    Oct 2009
    Castle Rock, CO
    The closest Home Depot had was a 1/8" extension which I could then connect to a 1/8 to 1/4 adaptor, then hook a 1/4" fitting for the air compressor.
    But I have to remove the entire test cock and use this instead. Not the most elegant solution.
    The problem with the test cock on my 800M4QT is that they are NOT 1/4" ... they are larger, probably 3/8" .
    This looks like what I probably needed:
    http://www.farm-home.com/mn/v11_cata...95-2328~~~~~~~
    DIY Junior Member cn90's Avatar
    Jan 2009
    Nebraska
    For those who want to connect Air Compressor to Hose Bib, here is the setup I use (cost about $8 to put it together):
    - Part 1 is the standard 1/4" Air Compressor fitting
    - Part 2 is Adaptor to go from 1/2" (Female end of the Hose Coupling #3) to 1/4"
    - Part 3 is Hose Coupling.
    Ace Hardware PN 71941
    http://www.acetogo.com/product/71941...fhtx12fip.html
    Use Teflon and you are good to go.
