is it a two line system with a jet in the well? If it is, the jet can get plugged with crap and cause your problem. Pull it up again, remove the jet and clean it out.
Hi all,
I'm new to the forum and I have a problem that I am helping my uncle with at his place. I have a similar problem at my house (miles away, very different depths) and I'm hoping that helping him will let me solve my own problem.
His pump will kick in and begin building pressure, but it will only build to 28 psi.
He has set the switch to run at 20/40 for the time being, so what he is doing is running the water very sparsely. When the pump kicks in, he goes down and turns it off and back on again. This way, he is keeping the pump from burning out.
He assumed it was a problem with the foot-valve, so we dug up the well head and pulled it out. We replaced the lines and the foot-valve and put everything back down and hooked it up. But, we are still having the same problem.
Any ideas?
Thanks in advance,
Tim
It is a two line system as you guessed.
There is a jet, and we ran a lot of water through it. To check that it was clean I placed the end of the jet that leads to the foot valve in a bucket of water and blew into one of the other ends that leads to the house. Water splashed back up at my face, so I took that to mean that it was pretty clean (my face...not so much).
Any other ideas?
Tim
Things that can cause that problem
something in the jet
Jet is worn out
Suction line leak
Pressure line leak (the on to the jet, smaller pipe)
Worn out pump
I'll still be on something in the jet. You really need to run something through the jet like a straight coat hanger
The nozzle in the jet assembly is plugged or partially plugged. You need to remove the jet assembly and remove the fittings from the larger inlet pipe on the assembly. Then remove the Venturi it's a long tube unually protuding out of the jet assembly (it's a right handed thread). take a 3/4" long socket and unscrew the nozzle deep in the jet assembly (it's a right handed thread as well). Then clean out the nozzle. It should have a 1/4" hole in it. Check the nozzle hole with a 1/4" drill bit. . . if it's a larger hole replace the nozzle or the whole jet assembly. Clean everything up good and replace everything being sure nothing plugs the nozzle again. Reinstall everything, prime the pump and you will have pressure again! Pumps don't build much pressure, they just move the water. The jet assembly builds the pressure.
Porky, MGWC
Master Ground Water Consultant
