Results 1 to 5 of 5
Thread: washerpan or drain
    DIY Junior Member Pabs's Avatar
    Oct 2009
    Moncton, NB (Canada)
    Default washerpan or drain
    in my bathroom reno, I'm putting in my washer dryer (stacked) over tiled floor.
    for added safety do you guys recommend adding a drain on the floor or a washer pan?
    and, how is this tied in to the existing plumbing? can you hook that up the same as a sink or do you just run a line to your storm drain in the basement?
    Pabs
    Put a pan with a drain if you're going to do anything. When the hose breaks we hope most of the water goes into the pan. Out here we run the drain anywhere out of harm's way (outside, basement sump pump,, etc.). No need to plumb a trap and vent. Maybe put a screen on the outlet to keep insects or rodents out.
    DC
    Previous member
    Jul 2009
    North of the Mason dixon Line
    If the washer is installed on finished floor it must by code have a pan that is either drained or has an alarm.
    Oct 2009
    cool, will do... that and I'll change the hoses every now and again... get them before they fail!
    thanks
    Install a single handle shutoff with hammer arrestors so you'll be more likely to actually shut the water off when you are not actually running the WM.
