Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Thread: Drilling holes in joists to run cable
    Jul 2007
    USA
    Default Drilling holes in joists to run cable
    Due to the layout of my basement and mostly AC ducts some of my joists are starting to look like Swiss cheese with all of the small holes I am drilling in them to run cable.
    I know holes must be drilled at least 2 inches away from the edge of the joists and can be drilled anywhere along the joists (notches have different rules) but am I missing something important here?
    Extreme DIY Homeowner Scuba_Dave's Avatar
    Jan 2009
    South of Boston, MA
    Are you running NMB?
    I can usually fit 3 wires thru one hole - maybe 3/4"
    DIY Handyman (not 4 hire)
    I have enough to do to my own house
    Jul 2007
    USA
    No, I always use MC.
    Licensed Electrical Contractor Speedy Petey's Avatar
    Jun 2007
    NY State, USA
    Quote Originally Posted by ian gills View Post
    no, i always use mc.
    Why???....
    Answers based on the 2008 & 2011 NEC. If you're on the '14 already I feel sorry for you.
    Jul 2007
    USA
    Sorry I did a typo. I meant AC not MC.
    In England we very rarely get to buy armored cable. It's normally only used for commercial and security types of work.
    So when I saw my house was wired with it in the US, I jumped at the chance to continue using it.
    I like the way the sleeve is less susceptible to damage than Romex. I also feel a little more comfortable running it in semi-exposed spaces in my unfinished basement that might otherwise require conduit if I used non-metallic cable e.g. runs up the wall from light switches. The real benefits are when it is behind walls. The sleeve will provide a hint to somebody that may someday inadvertly start drilling into it. Not so with Romex.
    Of course, not all gauges of wire are available in AC, and it cannot often be used outside, but 14 gauge and 12 gauge commonly are. I really do not see why professional electricians would use anything else. A little more work with AC brings a lot more benefits than Romex.
    Jun 2007
    NY State, USA
    Quote Originally Posted by Ian Gills View Post
    Completely valid opinion.
    Not so much any more. AC is getting very hard to find. Pretty much everything is MC now with an AL sheathing. You will go through that almost as easily as NM cable with a drill.
    MC cable is available in any configuration you would want.
    You really think this, huh?
    Jul 2007
    USA
    I really do think that. The metal sleeve looks so neat!
    I have never seen commercial work done in Romex, so there must be something in MC/AC.
    So come on Petey, treat your next customer to some nice cable. You'll enjoy it.
    Default holes
    As far as the holes are concerned, just consider them "lightening holes" the same as the ones in the beams of semi trailers. But, "The sleeve will provide a hint to somebody that may someday inadvertly start drilling into it." I would not put even a penny on any bets that it would save the wire. I had a carpenter who was installing shelving in a bedroom. He had a hard time getting the screw to hold, but eventually he drilled a hole in the steel gas pipe which was inside the wall.
    Plumber Cass's Avatar
    Nov 2005
    Ha Ha Ha Ha...now thats funny...
    Jul 2007
    USA
    Thank you for the useful observations.
    Jun 2007
    NY State, USA
    I see it quite often. Mainly wood framed structures.
    No problem. I'll send you the bill for the extra cost.
    Have you purchased any lately? It is considerably more than NM cable. And my labor will definitely be more.
    I'm sure you won't mind paying.
    Of course I use it when I feel it is needed and/or required. Like above a commercial drop ceiling.
    You must not have worked with the stuff much. I hate it.
    Pulling it sucks.
    It takes up MUCH more space.
    You have to use metallic boxes.
    It does not go around corners nearly as easy.
    And the oily finish makes your hands and clothes black and greasy.
    Jul 2007
    USA
    Pulling it sucks.
    You missed one of my favorites. Using the anti-short bushings and struggling to get the red indicator through the cable clamp.
    Just a FYI: Red heads (anti-short bushings) are not required on MC cable but IMO is a wise practice/cheap insurance, they are required on AC cable by the NEC. Keep it up.
    Default hole
    The hole in the gas pipe was only funny when he heard the hiss and had to run outside to find the gas meter and turn it off. The gas line was right behind the drywall so we could not use a union, if it were proper to install one inside the wall. So we had to find a 1 1/4" left/right coupling and nipple, then cut and thread both sides of the pipe in the wall, and finally maneuver the left/right into place and tighten it, which anyone who has ever used one will testify is not the easiest thing to do to get both sides tight at the same time.
    Nov 2005
    I can see it now......
