Results 1 to 6 of 6
Thread: Vent for Roman Tub
    Default Vent for Roman Tub
    We're doing a bump-out of our bathroom (slab floor) to install a roman tub. Is there any reason to not have the vent stub up out of the slab alongside the tub drain (but outside of the tub footprint), and then run horizontal the couple of inches into the wall before turning vertical to the roof?
    The bump-out wall is going to be busy with framing (shear walls), and my thought was that by bringing the vent up within the tub platform, I can then route it into the wall to accomdate the framing, rather than framing to accomdate the vent.
    DIY Senior Member seaofnames's Avatar
    Jan 2009
    Mission, BC
    You cant run horizontal venting until you are above the flood plain of that fixture, using whatever measurement your local code states.
    Default vent
    Just use 45's for the offset and you will be okay.
    So penetrate the floor, and then a 45 to get into the wall? That'll work. Thanks!
    Default vent
    It is done all the time.
    Got my Underground Soil-Pipe sign-off! Thanks for your input
