Thread: Wondering if I have a circulator pump problem
    DIY Junior Member
    Oct 2009
    RI
    Question Wondering if I have a circulator pump problem
    How can you tell if a circulator pump is bad, on a gas forced hot water heating system?
    Previous member
    Jul 2009
    North of the Mason dixon Line
    Hold onto the pipe directly above it with the thermostat calling and the boiler at temperature. If you say ouch the circulator is working.
    Default pump
    If the pipe is cool when the circulator is off and hot when it is running, then the pump is probably working, but even that is not a good indication tnat it is working PROPERLY.
    Most circulator pumps have very little head pressure and won't be able to push water if there's an air pocket somewhere higher up. You'd need to ensure you got all of the air out first.
