Results 1 to 4 of 4
Thread: Pressure Drop Across Thermostatic Mixing Valve
Hybrid View
    Default Pressure Drop Across Thermostatic Mixing Valve
    I’m remodeling my laundry room and this space feeds a hose bibb that is used for washing cars, cleaning tools, etc. My location is NY, so it gets cold here. Washing road salt off the cars and cleaning tools after tiling last winter was quite painful. I’m considering changing out the supply to the hose bibb from a single cold water feed to a hot/cold water feed through a Watts ½” lo-temp mixing valve (60-120 deg F). Will I get an unacceptable pressure drop across the mixing valve? Would it help to install a ¾” valve with reducing couplings? The other option is to eliminate the mixing valve and install a pair of check and ball valves to manually mix the hot/cold. The valves will be inside the wall with an access panel. Any suggestions?
    Thanks in advance,
    Scott
    Master Plumber nhmaster's Avatar
    Jul 2008
    S. Maine
    Good news everybody, you can buy a sillcock that will give you hot, cold and mixed water.
    Thank you for the reply, but unfortunately that will not work. I do not have hot water running near the hose sillcock. In order to get to the area of the sillcock, I would have to tear down a finished wall and also work in around the oil tank. There is limited, if any, space to maneuver around the tank. The room that I have open has hot water and feeds the cold to the sillcock. My though is to mix the water here and use the existing cold water supply to sillcock as a mixed supply.
    Jul 2008
    S. Maine
    A couple of ball valves and a tee will do the same thing at 1/3 of the cost.
