evanob
I have a newly installed one-piece Guinevere Toilet. Approximately 50% of the time the flapper lands off center and distorts after closing and allows water to leak around the edge causing the toilet to run continuously and often making a strange whistling sound. I do not believe this is an installation problem. The flapper attaches to the drain in only one manner. The flapper seems too soft and flexible. Toto sent me another identical flapper and I have the same problem? I am thinking of adding some plastic to the back of the flapper to stiffen it enough to prevent this problem. I can't be the only person with this problem, can I? Toto needs to manufacture a stiffer flapper to correct this problem. With the water running so often instead of saving water we are wasting water with this new toilet!
