Thread: Installing a Big Box Store Electric Base Board Heater
    DIY Member 87vertgt's Avatar
    Sep 2009
    Chicago,IL
    Question Installing a Big Box Store Electric Base Board Heater
    Amps : 6.25 A
    Assembled Depth (In Inches) : 2.5 in
    Assembled Height (In Inches) : 6.75 in
    Assembled Weight (In LBS) : 13.60 lb
    Assembled Width (In Inches) : 72 in
    BTU Heat Rating : 5118 Btu/h
    Color / Finish : White
    Depth : 2.5 in
    Energy Star Compliant : No
    Fuel Type : Electric
    Heating Area : 150 ft²
    Height : 6.75 in
    Maximum Wattage : 1500 W
    Thermostat : No
    Vented : Yes
    Voltage : 240 V
    I am guessing to run a 10 gauge wire. 30 amp fuse? can I run two of these on 1 line?
    Jun 2007
    NY State, USA
    Quote Originally Posted by 87vertgt View Post
    WHY????
    Why not #12 on a 20A?
    Absolutely. You can even put two on the same 20A circuit.
    You can run 14/2 on a 15A breaker and have no problems and be code compliant.
    http://www.inspectpa.com/forum/forum.php
    My answers are based mostly on the ICC codes. Advice given is my personal opinion and every person performing work should acquire a permit from his/her jurisdiction and get the work inspected. My opinions are not directions to follow for DIYs or professionals
