Originally Posted by
One of my customers uses an Electric Tankless for washing wine barrels.
Like you, he needs an endless supply of heated water.
Once the job starts, he's washing until every last barrel is clean.
He has a winery, and I've seen how many barrels he has to clean.
The other wineries in Woodinville use tankless too.
If you use electric, the electrician brings in the proper breakers and wire for it.
They use much more power then a two element tank heater.
A two element tank heater only heats with one element at a time.
So unless you have plenty of stored heated water beforehand, you will run out.
Or you can also use gas.
