Considering the weight of cast iron tubs, the more common technique is to smash it up with a sledgehammer & remove the pieces. Careful of the sharp edges, though.
I assume you mean "wide"? Good luck finding a tub that narrow, the narrowest nowadays are 30. What you should do, depends on your exact setup. Can you make the endwall a bit wider?The new 4 piece tub sets at the big box stores are not an option because the area for the tub is only 28.5 inches deep and they are all 32 inches deep or deeper. Basically we never arrived at a price b/c there are so many variables at this time. What do you think we should do?
