Page 4 of 7 FirstFirst 1234567 LastLast
Results 46 to 60 of 98
Thread: 14" Rough-In Toilet Choices
  1. #46
    The Caruso is not one of the bowls that use a unift.
    You do realize that there are three unifits, and they they need a bowl that uses them. In your case, the 14" unift would move the bowl closer to the wall 2"
    There is no such thing as a 14" bowl.
    That is way something like a unifit is used to move the bowl back closer to the wall.
    You can't use these with just any toilet. The bowl has to be designed to work with them. The one on the right is the 14"
  2. #47
    DIY Junior Member tjk045's Avatar
    May 2011
    Iowa
    Oh...and I can't wait to tear into the bathtub. I'm sure I'll have 50 problems with that as well
  3. #48
    May 2011
    Iowa
    TOTO CST715 Round Carusoe Two Piece Toilet 1.6 GPF
    The TOTO 1.6 Gpf toilet received high ratings in independent laboratory performance tests. With a powerful and quiet flush design, the toilet also offers a large water surface.
    Key Features
    Round Front Bowl - C715
    12" Unifit rough - in
    Streamline Tank and Cover - ST706
    Complete with tank trim and coupling components
    Low consumption (6 Lpf / 1.6 Gpf) gravity flushing action
    Tank fittings, complete with flush valve, ballcock, and chrome - plated trip lever included
    Five Year Limited Warranty
    NOTE:Seat is not included. Refer Recommended Accessories for Toilet Seats
    Product SKUs Product Options
    C715-03 Bone
    ST706-03 Bone
    C715-11 Colonial White
    ST706-11 Colonial White
    C715-01 Cotton White
    ST706-01 Cotton White
    C715-12 Sedona Beige
    ST706-12 Sedona Beige
    TOTO Warranty
    CST715 Product Specifications
    CST715 Product Install Guide
    Bowl Height 14.63
    Bowl Shape Round
    Collection Carusoe
    Configuration 2 Piece
    DA No
    Depth 26.13
    Flush Type Gravity
    Gallons Per Flush 1.60
    Height 28.38
    Installation Type Floor Mounted
    Lever Placement Left
    Material Vitreous China
    Rough In 12
    Seat Included No
    Trapway 2.13
    Trip Lever Placement Left
    Width 19.50
    TOTO Round Carusoe Two Piece Toilet 1.6 GPF - CST715
    1.0 (based on 1 review)
    Ratings Distribution
    5 Stars
    (0)
    4 Stars
    (0)
    3 Stars
    (0)
    2 Stars
    (0)
    1 Stars
    (1)
    Low water level in bowl
    Poor flushing performance
    Best Uses
    Comments about TOTO Round Carusoe Two Piece Toilet 1.6 GPF - CST715:
    This is a bad toilet. The claim to "large water surface" is a joke. Ours had very little water in the bowl. I called Toto tech support and they had us measure the surface area, which was 6" x 7" as opposed to the 8.5" x 10" they said it should have. They sent a new bowl. No better. Also, you have to flush it twice almost every time for anything solid. It has a very weak flush. I had heard great things about Toto in general and we have a Drake that works fine, but we are extremely disappointed in this model, as well as the misleading claims about it on this website.
    Bottom Line No, I would not recommend this to a friend
    (1 of 1 customers found this review helpful)
  4. #49
    May 2011
    Iowa
    Wow...that copied more than I expected. Anyway, half way down that post, it claims 12" unifit...is that not true?
  5. #50
    May 2011
    Iowa
    Ok...let me put it this way. If this was your house, and you didnt want to spend 4-500 on a toilet...what would you do? Leave it and "hide" it? Or do you have(hopefully) a better solution?
  6. #51
    May 2011
    Iowa
    I've been in this house for 12 years. Never had a problem with the toilet. Still don't except that it's somewhat ugly and is 3 1/2" from the wall. Which I never noticed and didn't bother me until I started tearing things apart
  7. #52
    May 2011
    Iowa
    But unless I'm missunderstanding you, I have to buy a 12" or 14" rough in(one of the ones you listed) and a 14" unifit, or I have to leave it as is
  8. #53
    May 2011
    Iowa
    I'm about to tear up the concrete the way I feel now
  9. #54
    I think you should tear up the concrete. Just smash it up.
    By the way, why would you install a Carusoe when you can get a Drake for 200 bones.
    Neither of those are helping your 15.5 rhough
    I say jsut tere it out.
    Joe the Plumber
  10. #55
    The toilets that are designed to use the Unifit adapter all come with the 12" one. If you want to move the bowl, you throw that away and also buy the size unifit you need (in your case the 14"). By using this longer adapter, it pushes the whole thing back towards the wall an additional 2" (from the stock 12" one). There's no credit for the 12" unifit, so you end up with a piece to trash. Seems annoying, but that's the way they do it. The II versions (of those available) have better bowl wash than the 'original' versions (without a version number in the product name). But, I have two Totos with the Unifit (a Vespin and a Carlyle), and both work great. This flexibility costs as they are a bit more complex to manufacture, and they actually have some style. If the gap isn't that big, and you want to save some money, the Drake or Drake II are good performers, but you'll have at least that much gap, if not more. As Terry mentioned, the toilet must be made to use the Unifit, and only some Totos do - it is not a universal adapter that can be used with other brands or models except those designed for it.
    Most people don't remodel their bathrooms very often, and this decision will stick with you for probably 15-20 years or more, so over that time, it makes some sense to bite the bullet and do something you'll like. The cost to move the flange would be much more than a toilet that would move it closer to the wall (a Toto with a Unifit). But, you'd still have close to 2" gap as if it was perfect, there's normally a 3/4" gap. Yours is 1.5" further out that even that non-standard standard 14", so it should be 2.25", if you measured correctly. You can fudge the attachment maybe a 1/4-inch or so, and probably get it to 2", but unlikely to get more.
  11. #56
    May 2011
    Iowa
    Thanks for your replies....it's time to tear it up!!!
  12. #57
    DIY Junior Member calvin's Avatar
    Jul 2011
    Amherst, MA
    Default Insulated tank toilet w/14 in rough in
    My house is quirky, and my only bathroom is quite small. I'm planning to replace my Homart toilet, which seems to be original to the house, because it gathers so much condensation in the summer that it's rotted the plywood subfloor. Our mixing valve can't handle extreme heat and humidity, so now we're going to try an insulated tank.
    I was set to order a Toto Drake (round seat) until I realized I have a 15" rough in. From the discussions here, I understand I could theoretically use that model anyway; however, it would leave no leg room.
    From my research, none of the Toto toilets is available with both 14" unifit AND an insulated tank. Is that so? If that's the case, would you please suggest the best alternative solution?
    So far, it seems my choices are to re-rough in the plumbing, which sounds expensive, or to go with the Gerber Avalanche, which seems unpopular. What say you?
    Thanks for your thoughts on the matter.
  13. #58
    Yakima WA
    Old toilets used 3.5 gallons of water per flush which totally emptied the tank. The incoming water was very cold and this caused condensation especially in very warm climates. New low flow toilets use on 1/2 the water in the tank, and even less in the newer 1.2 gpf models. Since the water in the tank is at room temperature, and only half of it is used, the refill is only half a tank and than mixes with the already room temperature water. The result is no condensation. So, an insulated tank is really not needed.
  14. #59
    Jul 2011
    Amherst, MA
    I've heard that and hope it's so, but I'm hesitant to do a new toilet and floor only to learn that we needed an insulated tank after all. It's a relatively small investment at this point for peace of mind, esp. since some materials we're considering (marmoleum and beadboard) would not fare well with standing water.
  15. #60
    A lot of the old toilets I pull out have molde on the bottom. Those tanks emptied out and refilled with cold water.
    I don't see that problem on the new toilets we're installing.
    I have sold a few insulated tanks, mainly in Alaska.
  1. TOTO choices for 11" rough in
    By tsdad1995 in forum Toilet Forum discussions
    Last Post: 02-13-2012, 06:53 AM
  2. What are my choices with 13 3/4 rough in?
    By moneypitowner in forum Toilet Forum discussions
    Last Post: 11-15-2009, 09:04 AM
  3. budget toilet choices
    By avalon in forum Toilet Forum discussions
    Last Post: 10-10-2009, 06:01 PM
  4. 14" Rough-In Toilet Choices
    By cgskiking in forum Plumbing Forum Discussion & Blog
    Last Post: 09-30-2009, 03:16 PM
  5. 10 inch rough in choices
    By clueless2 in forum Toilet Forum discussions
    Last Post: 08-14-2005, 03:53 PM
