when you say that you turned of f your $3000 rainsoft unit,
do you mean that you hit the bypass lever on the back of
unit or did you simply just unplug the unit....?????
If you did not by pass the water from going through the unit,
and water has gone through that filter for the past 3 years,
the unit is probably ruined by now...
the unit can be serviced if you have bypassed it....
you dont have to call rainsoft, their are probably other
companies in the phone book that will work on them...
make it clear from the get-go that you only want it repaired...
as far as buying a Sears unit, they are total DOGS...
the waterboss is probably worse than sears...
Neither unit is easy to service, and the sears
repair men dont know what they are doing.
its better to get a two tank system instead of either one of those...
you can get a top of the ine CLACK unit installed for
around 900, or you can buy one on line for 600,
so why do you want to mess with these hardware
stores off brands and get yourself in trouble again??...
http://weilhammerplumbing.com/galleryii/
