Thread: Wiring Help for 2 Outlets (One on a Switch)
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default Wiring Help for 2 Outlets (One on a Switch)
    The power comes in to a box with 2 outlets. The goal is to have one of the outlets on a switch. The switch is not in the same box (6 feet away from outlets). Does this require 3 wire to the switch?
    Thanks for any replies
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    Electrical Contractor jbfan74's Avatar
    Jun 2007
    Newnan, GA
    Quote Originally Posted by molo View Post
    No, it can be done with 2 wire.
    Remark the white wire red or black and connect it to the incoming hot wire.
    Connect the wire to one side of the switch, and take the black wire back to the receptacle, break the tab and connect the wire to the top or bottom half.
    Yes I am A Pirate-Jimmy Buffett
    Sep 2006
    cold new york
    Quote Originally Posted by jbfan74 View Post
    Will this make only half of the outlet switched or the entire outlet? There are 2 outlets and we want one switched and one not switched.
    Gore Vidal.
    There are tabs between both the neutral screws and the hot screws. Leave the neutral tab intact. Put a pigtail on the incoming hot lead, break the tab on the hot side, run the hot lead to the outlet you want to be always hot, and the switch leg from the switch to the other. The other wire from the new 2-wire cable to the switch gets connected to the pigtail to provide the hot.
