Thread: metering
    DIY Junior Member
    Sep 2009
    Napa,CA
    Default metering
    What I have, is a need to renew a meter in a 3" line, to satisfiy local code among other reasons ( it would be a good thing to have regardless of code)
    Due to the substantial price difference between a 2" meter and a 3" meter, I would like to reduce pipe size ( staying with the 5 diameters pre- and 10 diameters post meter) to install the less costly unit. What do I need to calculate to see if it'll work? GPM, pressure, all of the above? It is feeding a 600'long, 30year-old galvinized pipe , from a 20K gallon storage tank, and the placement would be near the tank end.
    Thank you very much, Jeff
    Plumber jimbo's Avatar
    If this is public water supply, then yes the meter capacity fee will be quite less on a 2" than a 3". Base on your long run, you do need to determine GPM usage to size the outgoing pipe and minimize velocity and loss.
    You would need the specs on the meters to see if a 2" meter is capable to deliver the total GPM you need.
    From a USA Bluebook catalog, I find this data:
    2" meter..... 2 to 160 GPM range, approx. 80 GPM max continuous
    3" meter 2 to 650 GPM range, approx. 325 GPM max continuous
    DIY Junior Member
    Sep 2009
    Napa,CA
    Thanks. You have me pointed in the right direction. Our system is a surface water source, and a new filtration system. The new system has a meter,and the one I am refering to would go in line after the storage tank. I should have looked at the book too . . . Thanks again, JC
