Where would I put chlorine?
tkeoki
Texas
I need to disinfect our well. I've attached a picture of the top of the well housing and am wondering where I would enter the disinfectant? If you need addt'l pictures from a different angle, let me know--thanks.
Gary Slusser
That's all folks!
I think you need to remove some of teh dirt and see is you can find the sanitary seal and casing. Then it looks like you'll have to pull the pump some to get bleach water down the well.
If you have galvanized pipe down the well, you may not be able to this without a pump hoist truck.
Why are you doing this, bacteria contamination? If so, most times shocking a well won't get rid of the problem on a permanent basis.
tkeoki
Texas
I think the sanitary seal is in the picture; just hard to see, I'll get a better picture this morning.
Well, I'm still going to get confirmation, but I think I might have some sulfur-reducing bacteria as I get a slow buildup of black slimy goo in the toilet tanks, and when guests come over they say they can detect a very faint sulfur smell when water comes from the tap or when they take a shower(I think I'm used to the smell 'cause I can't smell anything). If the water sits for a period of time, the smell goes away.
I was going to look into maybe using some chemicals from Cotey chemicals instead of using the traditional bleach method.
The only test results I've gotten thus far all show good quality, but I need to do some additional tests. i.e. Manganese, Sulfates, Chlorides, Hydrogen Sulfide.
From a pool shop:
PH: 7.04
Calcium Hardness: 102
Total Alkilinity: 171
Cyanuric Acid: 8
Copper: 0
Iron: 0
