Results 1 to 6 of 6
Thread: Leaking diverter spout
    DIY Junior Member David Mims's Avatar
    Sep 2009
    Byhalila, MS
    Default Leaking diverter spout
    I'm hopeful ya'll can help a brotha out. I seem to have the only such tub spout on earth and can't find a replacement. It's leaking around the o-ring, which I've replaced. I have another tub with the same fixture, and this spout leaks on both while the other spout seals on both. I think daughter pushed down it and broke the plastic inside but can't get it apart to be sure.
    The stem is about 1 1/2" from the threads to the o-ring. Looks like it's soldered onto 1/2 copper pipe. The o-ring is 3/32" by 1 1/8" od. The spout is threaded on the near end but smooth for the o-ring to seat against farther inside. It appears to have a brand stamp at the base SA surrounded by a C. Hope you can see the picture.
    I just need to know what brand it is and where to find one or one similar to replace it. I am much obliged for any insight you fellars might offer.
    Plumber jimbo's Avatar
    It is a Delta RP17453. Available at any good plumbing supply, not necessarily at a home center.
    Sep 2009
    Byhalila, MS
    Thanks Jimbo!
    Default spout
    It would have been hard, if not impossible, to damage the "O" ring, so you may have a different problem. Call Delta customer service and have them send you a complete new spout.
    Sep 2009
    Byhalila, MS
    True the o-ring was not the problem. Ordered a new spout online Sunday which arrived UPS last night. Great service from ********, and thanks again Jimbo. Problem solved!
    Default spout
    Delta might have taken a little longer, but you would not have had to buy it.
