jrkonneker
I have a toilet base leak.
The flange is installed level with the floor.
When I removed the toilet, the entire wax ring stayed with the flange and left no wax on the bottom of the toilet at all. I assume this means that I should install 2 wax rings to obtain enough compression for a good seal.
If I install 2 rings, 1 with the rubber funnel and the other without, what order should they be installed? The ring without the funnel against the toilet base and the ring with the funnel on top of it so it is in the pipe?
Thanks for the help.
