Why? Upsizing the relay could lead to frying the pump motor.
Hello All. Can Anyone Cross referance my Well Control Box Potential Starting Relay, to a 50 amp points rating, verses my 35 amp one? I Now have an "ELECTRICA" PN#
RVA 2AL KL Starting relay for my 3hp pump. I want a Starting relay with the same specs/ PU-224-252, and DO-40-105, (or close to it. Except I want one with a 50 amp points rating), verses my 35 amp rating, that I now have. Also the better the material the points are made out of would be nice!!!! Any Brand will do! Any Ideas, or part numbers would be appreciated!
lzenglish
Why? That is a long story, lets just say because I want too! Now I assure you I have not, and would never, Jumper my thermal overload switch (that protects the pump from frying), or increase my circut breaker amp size (which also protects the pump from frying). If you have an (Air Maker System), with an (AVC), and snifter valve etc., you would know that it is inevitable the AVC will go bad, or the tank will water log at least every now and then. When it does it short cycles, when it short cycles, the starting relay points (Pit), until the themal overload can trip. Once this happens, the points are never the same on a cheapo Relay. As long as the pick-up, and drop-out votages are the same, it does not matter how big I go on the size, and quality of the points.
In that case then I would head on over to grainger supplies web site. they probably have what you need.
Hello again, and thanks for your replies! As far a Grainger goes, I have had an account with them since 1975, and they are good people, but do not have the technical knowlege that I need, (And do not list the relay I'm seeking). This is the reason I have posted this thread. If I get no (cross referance responses), I will start calling the manufactures, on Monday. Just thought I would try to save a few bucks on phone calls!
Wayne
Senior Stationary Engineer(retired)
Thanks, I will put them on my list to call!
Take care,
Wayne
GE apparently makes one with 50 amp contacts.
Here is a link to literature:
http://www.geindustrial.com/publibra...TION%7Cgeneric
Thanks for the Link !
Wayne
30 mV or less across closed relay contacts at rated current = good contacts. More than 100 mV, bad.
http://www.google.com/search?hl=en&s...&aq=f&oq=&aqi=
The AVC only lets out excess air. If the tank gets water logged, it is because the above ground check valve, schrader valve, or the bleeder orifice in the well is not working properly. Larger contacts will help a little but, nothing can survive the electrical arcing that happens when the switch pops open and closed from a water logged tank. And if your switch is seeing this kind of damage, just imagine the damage to the motor. Solve the problem, not the symptom. There are devices like the Cycle Sensor that will shut the pump down before there is a problem.
See this link;
http://www.cyclestopvalves.com/prod_sensor_geninfo.html
Thanks. I have found a relay! I understand your point, but, but I think my New Heavy Duty Relay, will give me a more Reliable system. The pump is only 5 years old, and Not a (Big Box Store) drop in. Have you ever bought a (Heavy duty Device of any Kind)? I think a 35 amp rating is too small anyway, otherwise, why would they offer a 50 amp one? I cannot bunk out at the well house, if I could, I guess I would! Now my friend, what would you suggest, with a New tank, New Commercial grade, Psi Cycling Control, New Snifter valve, New AVC, No leaks, Proper Voltage, Tight Connections etc.? I do what I think I can, without breaking the rules, (such as bypasing Saftey Devices, That I have stated ! What would You say is the underlying Probem? Move? (just kidding)
lzenglish
PS Yes the AVC Only lets Air Out., If it is not fowled, or plugged! I Know this very well, as I have replaced Many of them!
The check valve that the Schrader screws into is the most important part. I don’t see where you replaced it. If this check valve doesn’t close properly, none of the other parts for the air charge system will work. Just using larger contacts, (that are meant for larger horse power pumps), will only move the problem further down the line. Probably to the 5 year old pump that may not last much longer. This has always been the main problem with air charge systems, which is why they made bladder tanks, so you don’t need all those little air charge parts that will fail. A device like the Cycle Sensor that looks for a rapid cycle and shuts the pump off before there is a problem would be safer for the pump and would keep the points from burning.
Thanks for your reply, Yes The Control Valve was replaced one Year ago! And is a (Very Top Grade One).!
Take Care,
Wayne
PS. A Well and Septic is a Beautiful Thing, as long as it Works!!!!!!!!!!
One plus, is that I'm a retired Senior Stationay Engineer, (that was Not handed to me at birth)!, But I'm not a Well Expert, as You people are, and I need all the advise I can get, and do very much appreciate Your advice, and keep it Coming please !!!!! Sorry about my bad spelling!
A 3hp motor should only draw between 15 and 18 amps so a 35 amp contactor is more than ample. Arcing points is arcing points no matter what the contactor is rated at and if the arcing continues it will burn up the 50 amp in the same amount of time. V-man is correct here, there is an underlying problem that has to be solved first.
