Results 1 to 6 of 6
Thread: Life expectancy of a bladder tank
    DIY Senior Member Bob999's Avatar
    Jul 2009
    Pennsylvania
    Default Life expectancy of a bladder tank
    What is the life expectancy of a bladder tank and what are the typical causes of failure? Is there is significant difference in life expectance between steel and composite tanks?
    Jul 2008
    S. Maine
    seen some better than 20 years old and still going, seen some go in 2 years.
    Quote Originally Posted by Bob999 View Post
    I've seen Gould's and Well-X-Trol last 20-25 yrs. The primary cause of failure is incorrect air pressure.
    Composite/plastic will usually last much longer but their bladder (bag) is not as 'robust' IMO.
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Default prelim numbers
    20
    20
    25
    mean = 13 yrs
    1 chance in 7 of lasting 25 yrs and 1 chance in 7 failing in 2 yrs.
    http://www.google.com/search?client=...UTF-8&oe=UTF-8
    If there's no penalty in letting it fail I guess I'd wait till it fails.
    DIY Junior Member Stacystark's Avatar
    Sep 2009
    Carlisle, KY
    Default Life Expectancy of a bladder tank
    I can only say that mine, which was installed in 1978 still works. It had a problem last year where water got outside the bladder in the tank, but my plumber was able to drain and fix it. He did say it may have damaged the pump.
    Seems he might be right, as now the pump is sounding a bit different when it kicks on. The pump, a 1/2 HP,was installed with the tank, also in 1978, so it's lasted a long time.
    Which is why I joined this Group. I am looking to educate myself on the mechanics of (relatively)shallow, non-submersible pump motors.
    Stacystark
    Aug 2008
    MD
    Quote Originally Posted by Stacystark View Post
    Stacystark
    How deep is your well. . .?
