Thread: Pex Wirsbo uponor tool
    Professional Plumber hydroflow's Avatar
    Aug 2009
    tennessee
    Default Pex Wirsbo uponor tool
    I am about to buy a Wirsbo expanding tool (manual). I met the local distributor and he is trying to sell me the auto rotating head. Has anyone used this rotating adapter and if so is it worth the additional $150 or so?
    Hydro Flow
    DIY Senior Member seaofnames's Avatar
    Jan 2009
    Mission, BC
    No. Just spend the extra few seconds spinning it yourself. Unless you are doing a ton of work with this tool, its not worth it.
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    The self rotating heads are really only worth considering if you are buying a powered expander.
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
    Aug 2009
    tennessee
    Thanks guy's. talked to the local distribution rep. He confirmed your opinions. Said the rotating head was not reliable. Spring loaded mechanism works perfectly until you put it in a tube then the spring is not strong enough to turn it.
