Results 1 to 5 of 5
Thread: storm door lock set
    DIY Senior Member Master Brian's Avatar
    Nov 2008
    Kansas
    Default storm door lock set
    I am looking for a new lock for a storm door. Problem is that what I seem to be finding is locks that take those small keys. The last two of these I've had seem to wear out quickly allowing any/most small keys to unlock the door. Not very safe.
    I recently had a storm door put on the front of my house that is actually keyed to my schlage key and I'd like something like that to retrofit the other door. So basically I am looking for a storm door lock set that works with a schlage/quickset "house" key instead of a standard "storm" door key.
    Nov 2008
    Kansas
    With the help of Google Images, I might have found what I need, but I'm not certain it will work.
    Here is the link http://www.wright-products.com/produ...cents_Designer
    The Georgian deadbolt and latch, which are the two at top of the page, are what we have on the door right now. The mortised lockset, which is shown at the bottom, is similar if not the same that my front storm door has and it takes a regular size house key. Does anyone know if something like that Serenade style, middle of page, would replace the Georgian style, but with a full size key?
    How hard is it to turn what I have into a mortised style? I'll go look at the door and I've downloaded the dimensions and such. Just curious if anyone has any feedback.
    Thanks...
    Plumber jimbo's Avatar
    I don't look at a storm door as part of the security. It is not that sturdy a door to begin with....probalby can be pried with an exacto knife, so to me it seems locking it is just an unnecessary PITA?
    Nov 2008
    Kansas
    I would agree on a lot of storm doors, but the one on the front with the "house key" seems very solid and has a deadbolt type of lock. Not sure how strong the glass is, but it's should be pretty tough.
    The one that I'm trying to change the lock out on, we were told by the manufacturer that it'd stand up to a sledge hammer. So it appears the lock is the weak point at this time.
    No, not main security, but it would be nice to know that someone can't just walk up and unlock it with any old key.
    Default door
    The type of lockset you can use on the door depends on what kind of "lockbox" it is fitted with. Most are not thick enough, nor do they have the required opening for the handle mechanism.
