Results 1 to 7 of 7
Thread: Basement insullation vs wiring
    DIY Member richrc1131's Avatar
    Apr 2008
    Central Connecticut
    Default Basement insullation vs wiring
    I hope this is the appropriate place for this question. Here it goes:
    I need to insulate my basement, but there is a lot of wiring between the support joists. I can get the insulation behind all of that, but I wanted to know what are the general code considerations in this situation.
    Do I have to do anything special at junction boxes or anything like that?
    Jul 2007
    USA
    A few things to consider and I am sure others will add more.
    First, you need to be careful when covering light fixtures with insulation. The lights needs to be rated for this purpose.
    Second, junction boxes need to be accessible. They cannot be hidden behind drywall. This may require the use of a) access panels or b) a suspended ceiling.
    Apr 2008
    Central Connecticut
    Possible silly question here: Is it safe to leave fiberglass roll insulation uncovered? Meaning, since I have to insulate the basement ceiling and I also have to install a drop ceiling, do I run any health risks by leaving the drop ceiling portion of this project for a later time?
    Jul 2007
    USA
    If it's got the paper backing on it, then technically this should not be left uncovered since it might present a fire risk.
    Apr 2008
    Central Connecticut
    No health worries though?
    Fiberglass insullation can shead fibers, so it would be a good idea to try to prevent that. Any air movement across it can result in a shower of fibers as can contact, which are not the greatest thing to inhale or to get on you. So, maybe staple up some plastic or paper. It should be fairly easy to remove, if desired, when you get to install the ceiling and won't take much time or money to install. Both faced and unfaced fiberglass will burn.
    Dec 2006
    Just googled up the msds for a random unfaced...
    http://docs.google.com/gview?a=v&q=c...ds&hl=en&gl=us
    section 5 says "non-flammable".
    Master Plumber Mark:
    do not hit your thumb...
    __________________
