Thread: How hard to convert floor to rear drain?
    DIY Junior Member davidq's Avatar
    Sep 2009
    Austin, TX
    Default How hard to convert floor to rear drain?
    We are at the framing stage on our new house. The guest bathroom is 5 feet wide, and I'd like to maximize space in front of the toilet. We have an in-slab 10 inch rough-in. I'm thinking we might want to convert this to a wall hung toilet, if we could do it without too extravagant a cost. The wall is 2x6. Thoughts?
    I would expect the change to the rough-in to be about $1500 to $2000
    A Wall hung toilet with bracket will run about $750 to $1200
    Installing the wall hung toilet will run about $250 to $400
    You can buy the best 10" rough toilet for about $500
    Much better then the wall hung will be.
    Or an adequate 10" toilet for $250 to $300
    Sep 2009
    Austin, TX
    Default Thanks much for thorough, helpful response
    I appreciate you and your contributors for all the (somewhat overwhelming, I must confess) guidance and information on this site. I will follow up in a separate thread to avoid mixing subjects.
    Thank you.
