Water ON causing a throbbing Noise
I have a foreclosed house. I got the water turned ON and have city installed a new Water Meter. I sealed the leaking valves and shut of non tap valves. Now when I turn out the water the noise is loud that neighbor came and ask if I needed help. If I try a few timees turning off and then turning ON after a while I get a chance that tap opens without noise. I shut down and start and it does the same. Does it have Air traped or fault meter? How do I get the air out? I tried having water ON next to the Water heater but no luck ...
