Page 1 of 2 12 LastLast
Results 1 to 15 of 28
Thread: Code for Dryer Venting
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default Code for Dryer Venting
    I am installing a gas dryer and would like to know if I can vent it down through the floor and out a basement window. Any ideas?
    Thanks for any replies
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    Not sure about codes, but you'd have a big problem if there was a leak, plus, I think you'd end up decreasing the efficiency by maybe a significant amount...hot air wants to rise, not be pushed down. Plus, if there was a leak, you could have CO, too. Having it rise, like in a flue, is both safer and more efficient.
    Sep 2006
    cold new york
    This would be in a flu pipe (rigid) but it would go downwards about 2 feet and over about 5' before exiting.
    Gore Vidal.
    Plumber jimbo's Avatar
    Actually, I don't see a code issue with dropping down and over. True that heat rises, but air has mass, and can be pumped down more easily than up. Efficiency will not be affected.
    Just exactly how you terminate needs to be worked out. You don't want moist air backfeeding into the basement through that window, or collecting in a poorly ventilated space.
    Sep 2006
    cold new york
    If this will work. I will probably eliminate the small basement window entirely to terminate the vent through.
    Gore Vidal.
    Jul 2007
    USA
    I installed a dryer vent window. So far so good.
    Plumber Cass's Avatar
    Nov 2005
    When all else fails read the directions...or call the Mfg. and ask..
    Extreme DIY Homeowner Scuba_Dave's Avatar
    Jan 2009
    South of Boston, MA
    Quote Originally Posted by Ian Gills View Post
    You bought a dryer window?
    This must have been after the 3rd wisdom tooth was removed
    My house they just cut the glass & put the vent in
    DIY Handyman (not 4 hire)
    I have enough to do to my own house
    Nov 2005
    Yes...but Ians comes with that nice wooden stand...I bet yours didn't...
    Jul 2007
    USA
    I'll let you know that that dryer vent window has been tested.
    Jan 2009
    South of Boston, MA
    Quote Originally Posted by Cass View Post
    Yes but mine has bubble wrap
    The bubble wrap window is now inside the garage
    I'd like to sya they cut the window glass & put in a piece of wood
    But in reality they just broke the window glass & put up a small piece of paneling
    The whole area will be cut out for a door to the garage
    They used to have the sump pump output going out this window too
    I moved it to the back window that is a storage area under the sunroom
    It then enters a drainage pipe that goes out past the garage
    The dryer will move to the right of the window & go out thru the rim joist
    Then a short jog to the right to exit the garage
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Quote Originally Posted by Scuba_Dave View Post
    I'm outta' here.
    Aug 2009
    Midwest
    I was disappointed that Ian's was not shiny copper though...
    Nov 2005
    Agreed...but Daves does have that Down Home Kentucky "I live back in the Holler" look with the bubble wrap....
    Just kinda gives you that warm feeling...
