Results 1 to 9 of 9
Thread: Welding a Heat Exchanger
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default Welding a Heat Exchanger
    Can this be done with a safe result? There is a 4" crack running up from the lower left corner of a heat exchanger on a stand alone Empire furnace. I want to be safe but if it can be done safely I may contact someone to do it.
    Thanks for any replies
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    Plumber jimbo's Avatar
    Welding cast iron is possible, but requires certain skill and the right equipment. Unless you are a skilled welder, I suspect it would cost you almost as much to have it repaired, as to just get a new furnace.
    Yakima WA
    Molo, here is a link to an article on welding cast iron. After reading it, I think you may agree that it may not be a worthwhile venture for your problem.
    http://www.lincolnelectric.com/knowl...ronpreheat.asp
    Sep 2006
    cold new york
    OK, Thanks for the responses. It doesn't sound like a good idea. Why do they make them so thin? This is an Empire that isn't that old and it's cracked!
    Gore Vidal.
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Quote Originally Posted by molo View Post
    How old?
    How did you discover the crack?
    Does your furnace have a flame rollout switch?
    Sep 2006
    cold new york
    It might be 10 years old. It is a vented stand-alone furnace about 3' high and 4' wide. We noticed the crack during a cleaning and inspection. I do not know if it has a flame rollout and I know this heater has been used with this crack.
    Gore Vidal.
    Aug 2008
    MD
    Anyone have CO symptoms? Any CO alarms went off?
    Only 1/6th of resi. HVAC stuff dies this early.
    My '82 furnace with no flame rollout switch was just checked and the tech found nothing wrong but I don't know how thorough a furnace inspection has to be to show "Due Diligence" and "Duty of Care".
    He didn't disassemble any panels and I am going to replace my old CO detector.
    Only 1/4th get to be as old as my NG furnace but he said this age wasn't unusual in my area.
    Engineer Furd's Avatar
    Jul 2007
    Wet side of Washington State
    Heat exchangers on forced air furnaces are rarely, if ever, made from cast iron. Mostly they are "aluminized" sheet steel, aluminized to reduce rusting. They are thin to promote heat transfer to the passing air stream. Rarely is welding a cracked heat exchanger successful as they will usually crack again either through or right along the weld.
    The one thing that is most common in promoting cracking is a blower set to too low an airflow for the heat input.
    Quote Originally Posted by Furd View Post
    Heat exchangers on forced air furnaces are rarely, if ever, made from cast iron. .
    Don't know his model specifically, but Empire makes top gravity vent wall furnaces. Nonetheless, I agree that the heat exchanger might be cast, or it might not.
