I am driving a shallow well about 15 ft. deep and hope to hit water at lake level at 10 ft. This is 20 feet inland from the high water mark of a clear water lake. I have a 40 ft. vertical climb to lift the water to the cabin, It is 400 ft. from the well and never more than a 25 degree slope at any one point with the average slope about 8 degrees. The elevation of the area is about 1200 ft above sea level. What kind of pump will do this? What size pump? Should I use 3/4 in. pipe out of the ground or something larger in diameter?
