Ball valves with drains
jf
I am replumbing a bathroom and was wondering if the small drains on the valves are bad about leaking or would it be better to use the ones without drains.
Thanks in advance
Plumguy
MA
Personally, I think the drains are waste of money, I have never seen a use for them including silcocks that are maintenance free!!!
Gary Swart
Yakima, WA
The only use these valves have are when you must drain a line to prevent freezing, and then only if the valve is at the lowest point in the line. Save yourself grief and use regular valves.
Plumber1
Florida
valves
I've never seen a down side to using stop and waste valves.
And they can be usefull if you have to dry out a line for sweating and not have to shut the whole building off.
