Thread: cold water pressure in faucet slower than hot water!
    DIY Junior Member m3gtr's Avatar
    Sep 2009
    montreal, quebec
    Default cold water pressure in faucet slower than hot water!
    I changed my bathroom faucet. Once I turned the shut off valve on the pressure as perfect! A few hours later the cold water pressure is extremely slower than the hot water. What could be the problem? Both cold and hot pressure in tub and shower are fine. I never had this problem with my old faucet.
    You might have washed loose some crud in the line or the washer in the shut-off valve might have broken up (assuming you didn't replace that as well - always a good idea 1/4-turn ball valves are good).
    Master plumber Jay Mpls's Avatar
    Sep 2008
    Minneapolis
    Pull the supply lines loose from the faucet and see if the pressure is good there.
    (Get a bucket and spray them into it.)
    If these are good you have the above mentioned crud problem.
    Last edited by Jay Mpls; 09-16-2009 at 08:44 PM. Reason: I'm from the planet Boron.
    Network Engineer rmelo99's Avatar
    Jul 2006
    I have/had this problem with one of my new faucets, the cause for me was that the faucet was a widespread faucet and the handles and spout were connected to each other via stainless braided hoses that have one loop.
    The cold water one "kinked" and caused low pressure out of that side, if u reached under and unkinked it the pressure increased 10x.
    Might be the same since I know the stainless between handles is typical if u have a 2 handle widespread setup.
