Results 1 to 12 of 12
Thread: AC Wiring for Rinnai R94LSe
    Electrical Engineer jdf405's Avatar
    Jan 2008
    Los Angeles Area
    Default AC Wiring for Rinnai R94LSe
    My Rinnai R94LSe has two electrical connectors on the bottom, one is a ~1" diameter white threaded plastic connector for the remote, the other is a ~1/2" black rubber grommet - I assume for the 120VAC.
    The black grommet will not provide any protection from the AC line pulling out and causing damage or shock. I though the hole in the chassis should be connected to with a 1/2" flex conduit, or at least a romex clamp to hold the cable tight. BUT its not a 1/2" connector - its just shy - I was unable to get a 1/2" connector in the hole.
    How have you seen this done? Thanks for your advice!
    DIY Senior Member zl700's Avatar
    Aug 2009
    Texas
    There is a 1-hole screwed clamp inside to secure the romex or cord.
    Jan 2008
    Los Angeles Area
    Quote Originally Posted by zl700 View Post
    I saw that clamp - it just seems to be a pretty light weight system for securing a 120V cable. My folks have a Rinnai and their installer routed flex conduit directly into the chassis, but this chassis doesn't seem to support that.
    Aug 2009
    Texas
    Yes I know, it was designed for a 3-prong line cord, which is an acceptable disconnect in most places.
    I don't know that for $3.00 they just dont put the cord and plug on the units?
    Except that they are cheap
    But I just read that Rinnai-Japan (parent) sent Rinnia-US 10 million dollars for operations capital (bailout) so things can't be good.
    Macintosh Computer Consultant/Tech macmikey's Avatar
    Dec 2009
    Phoenixville, PA
    Mine (Rennai R94LSi) came with the power cord attached and we have it on a dedicated 20amp breaker.
    No issues with holding it in place, seems very secure. Can't imaging it coming out of there unless vibration is really bad or it is in a plcae where anything can come in contact and possibly yank on it.
    If you are Takagi or Noritz, you might call it a "bailout" because they can't get any. For Rinnai it's called Marketing Funds. Ever hear any other lines on talk radio or XM? THat stuff is expensive. Rinnai knows what works. I think that is a big reason why Rinnai is a larger company in the US by a long shot in sales. Takagi got here first and they are #3. Noritz overtook them in their 3rd year if I remember correctly to take #2 spot.
    Aug 2009
    Texas
    Quote Originally Posted by Scott D. Plumber View Post
    It was a loan for capital operations, I wouldn't call that marketing funds.
    Your close, Navien actually overtook Takagi earlier this year and are now flip-flopping with Noritz for #2
    Rinnai's big advantage is the heater and fireplace lines boosting sales.
    They may advertise alot, but check the reports, they are not profitable.
    DIY Junior Member
    Dec 2009
    vinh city
    It is possible the pressure is dropping too low when multiple devices are on at the same time, say stove, WH, dryer, furnace.
    Jun 2009
    Penticton, BC
    Reroute the line if you have too and install your own romex connector.
    In the Trades AAnderson's Avatar
    Oct 2009
    Aptos, CA
    Could you quote your source?
    Oct 2009
    Aptos, CA
    Quote Originally Posted by jdf405 View Post
    You have three openings, one for power and Rinnai's only draw< 3 amps BTW, the other is for the contoller using a single pair 18 AWG and the last more like a grommet, is the access for the poteniometer used to adjust for low fire that electrician always manage to mangle.
    If you are going to do an exterior installation, use liquid tite flex and fittings and a NEMA 3 rated disconnect switch not a 3 pronged pigtail..
    Aug 2009
    Texas
    Anderson-
    Numerous trade magazines, August editions
    -Plumbing Engineer, The Wholesaler, Contractor Magazine
    Rinnai-Japan called it- "10 million dollar capital investment into their North America subsidiary".
    That wasn't to build a factory, but to give them working cash. Anyone paying attention to all the recent rep changes? Cutting commissions lowering commissions and demanding more sales in a downturn economy, is a sure sign of their fiscal condition.
    Tankless companies in the US all operate as a subsidiary, but as a stand alone profit center, buying and reselling the product.
    IMO, they dumped their product for too long into a small market that hadn't grasped tankless yet in an attempt to grow market share and get to and hold being #1. Now with the downturn of the economy, less pieces being sold, more competition, a ethnocentric attitude, opened too many distributors, lowered buying requirements, dropped prices, it has come back to bite them.
    One thing they finally did right, is put an American in charge that knows and understands the US, market conditions and US contracting.
