Results 1 to 15 of 17
Thread: Bath exhaust fan venting
Hybrid View
    Default Bath exhaust fan venting
    The geniuses that built my house connected the exhaust fans in both of my bathrooms to the cold air return tubes in my attic space. Is it ok to do that? Does not seem right to me.
    I would like to install new fans and when I do, would like to create a manifold with 4" duct and connect both fan's exhaust to a my drier vent stack going out the top of the roof. Does that sound lile an acceptable idea? Not sure if code will accept that.
    Great forums!
    Dec 2005
    SW Florida
    As far as I know you cannot connect the bath exhaust with the dryer. Take them out ot their own termination point.
    Exhaust into your return.........unreal.
    Matt
    Enjoying life in SW Florida
    Plumber jimbo's Avatar
    A dryer exhaust should not be shared with anything. It also should not go out through the roof. Unless you have a booster fan, the dryer performance and energy efficiency will be lousy.
    Combining 2 bathroom exhausts can also be trouble. If hooked up wrong, one will backfeed the other. Because the high moisture in the bath exhaust, it should also not go where you say it does.
    Jul 2007
    USA
    My bathroom is entirely code compliant and does not have an extractor fan.
    The window in it simply opens.
    I&C Engineer (mostly WWTP) Lakee911's Avatar
    Aug 2005
    Columbus, OH
    Quote Originally Posted by dabiz7 View Post
    That's a redneck humidifier ... or was it called a house stinker?
    Quote Originally Posted by Ian Gills View Post
    My bathroom is entirely code compliant and does not have an extractor fan. The window in it simply opens.
    I like both a window and a fan. Shut door, open window, turn on fan.
    Problem is people don't open the window--especially when it's cold.
    (When I remodel the bathrooms in my rentals I'm going to put the fan on a timer so that whenever the light comes on the fan comes on and stays on for a few minutes. Sucks when you're in for a sec to take a leak, but it will keep the room ventilated. Not many people know to turn the fan on when they shower. )
    Jason
    Dec 2005
    SW Florida
    Quote Originally Posted by Lakee911 View Post
    Or hot. It's almost always hot here.............
    Matt
