Results 1 to 9 of 9
Thread: Found something odd. . . .you ever see this
    DIY Junior Member wed68's Avatar
    Sep 2009
    louisiana
    Default Found something odd. . . .you ever see this
    I am in SW Louisiana and have been working in, on, or around houses all my life. I have plumbed, roofed, hung vinyl, framed, and wired em, but I can not figure out why you would put a bath tub spigot 6 inches off a tiled shower floor!
    This is in a 50 year old house in a rural community, I was looking at it to resell, but I can not figure out what the spigot were for the only thing you can get under them is your feet. You would have to either pull the shower knob up with you feet or bend over to pull it.
    Anybody ever see this across the country?????
    Plumber Cass's Avatar
    Nov 2005
    can you post a pic
    Sep 2009
    louisiana
    Default I will Try
    I will try
    Master Plumber nhmaster's Avatar
    Jul 2008
    S. Maine
    Handi capped accessable
    scratch-pad engineer and mechanical fabricator leejosepho's Avatar
    Nov 2006
    For washing and rinsing the shower floor without getting your hair wet?
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    I have never come across one, but the spigot is meant to be used as a "toe tester" so you can test the temperature of the water with your feet as well as flush out any cold water in the line before you turn on the shower, so you don't get scalded or blasted with icy cold water.
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
    Default spout
    I usually put them 12" to 18" above the floor so you do not have to bend over to operate the diverter. They are used so you do not get hit in the face with a jolt of cold water when you turn the valve on. The plumber who put it at 6" above the floor probably figured that it should be 6" above the tub rim so it must also have to be 6" above the floor, not having enough initiative to think why that would be ridiculous.
    I&C Engineer (mostly WWTP) Lakee911's Avatar
    Aug 2005
    Columbus, OH
    Quote Originally Posted by Basement_Lurker View Post
    Yup. I think that is it.
    Nov 2006
    Quote Originally Posted by leejosepho View Post
    For ... without getting your hair wet?
    Well, at least I was close!
