Jakobkraft
I'm a first-time homebuyer, just recently bought a 900 sq ft condo.
There are two bathrooms - one right next to the water heater room and one on the opposite side of the apartment. The shower closest to it gets hot water in less than a minute, but the shower on the other side of the apt. takes maybe 5 minutes before the water turns hot. The pressure is very good so I don't think there's anything clogging the pipes.
The water heater is a 30 gal A.O. Smith which is over 12 years old and only gives hot water when the thermostat is set to 'Very Hot', which, I thought, shouldn't be necessary. I called A.O.Smith and they told me that over time the thermostat core can wear out and so I should replace it eventually, even though it hasn't started leaking and still gives hot water.
My question is: if I got a larger unit - say 40 gal or 50 gal - would that make the water turn hot faster for the shower that's further away? Or is it simply the age of this unit which causes it to take so long to heat water a moderate distance away?
Thanks in advance for any info!
