Results 1 to 2 of 2
Thread: kinetico 30 need help
    DIY Junior Member
    Sep 2009
    ohio
    Default kinetico 30 need help
    hi, the disk on the top brine rinse backwash will not move from the position i manually put it in. the water just runs and runs and runs from the line down into my drain... any help would be great. thank you.
    I would guess there is a blockage in the water powered part or something broken in the drive train causing it to not rotate and drive the gears. So you take it apart or call the local Kinetic dealer for service.
    In the mean time I'd put the softener in by pass to stop the continuous flow of water to drain.
