Thread: flexible copper pipe question
    DIY Member pronouncedeyen's Avatar
    Sep 2009
    Baltimore, MD
    Default flexible copper pipe question
    Hi. When I was running some 1/2" flexible copper pipe last night through some joists I bent them into shape against the joist itself. In the process I created a bunch of little indentations in the pipe. I should have bent them straight first and then put them through the holes.
    Anyway, I attached 2 pics of the worst part of the pipe. Can I still use it or should I do it over with a new piece? None of the indentations go very deep but I'm wondering if they will be likely to turn into pinhole leaks later on.
    l or m tube?
    Sep 2009
    Baltimore, MD
    Type L - I'm a newbie.
    Default tube
    If it were not K or L, then it would have to be refrigeration, because M does not come in soft. You are probably okay since they did not seem to create kinks in the tubing.
