No vents installed in barn before concrete was poured.
STyler
Rock Hill, SC
I hope this isn't a major problem. I have a shower, toilet and two sinks going into my barn. The drain lines are all in and the concrete was poured, but there are no separate vent lines - just the drain pipes for each fixture. Is this a problem? How can the toilet be vented?
Cass
With no vents and a trap on each fixture you will have problems...besides not meeting code...
Who plumbed it????
Jay Mpls
Master plumber
Minneapolis
Pix may help.So..you have pipes up through the slab?
Sink lines from the slab continue up,get a tee for a trap and go up and become venting.
Shower and toilets are a different animal.
Pictures if you can.
STyler
Rock Hill, SC
I can't get pics until the next time I'm down at the barn. Pretty much all there is to see is a single pipe up for the toilet and a single pipe up for the shower coming through the concrete at the drain locations.
Does this mean I have to dig up the concrete to tie in vent lines, or is there an alternate method to get this up to snuff?
FloridaOrange
Plumbing Designer
SW Florida
+1
Could be wet vented and if installed correctly you'll have no issues and be up to code as long as your jurisdiction accepts wet vents.
Cass
Each fixture should have its own vent...
Concrete will have to be jacked up to install vents if there realy are none...
I would call in a plumber and let him ascess the situation and make recomendations...
FloridaOrange
Plumbing Designer
SW Florida
Not if it's correctly wet vented. Expanded explanation: the wet vent classifies the horizontal in slab pipe as the vent.
Here's an example of wet vented fixtures. This is correct, notice the only pipes that come out of the floor is the pipe for the lavatory.
STyler
Rock Hill, SC
Hiring a plumber is what got me into this mess. I'd rather figure out the solution before calling in another one.
STyler
Rock Hill, SC
I might be heading down this afternoon. If so, I'll try and take some pics.
I'll also have you guys look at the floor drain for the wash stall. Wanted a decent sized grate and I got a small PVC drain cover.
Cass
Is it that he won't come back...can you post pics ?...If he is licenced and pulled a permit he has Insurance and should be bonded...
STyler
Rock Hill, SC
Took him forever to finish up the job and it's impossible to get back in touch with him. It isn't worth the headache to deal with him for anything else. He's a "master plumber" - but I think he's well beyond the point that he should have retired.
Permits are a non-issue. In that county, you pull a single permit (construction/electrical/plumbing) for an agricultural building - then the county is completely uninvolved. They don't do inspections on any part of the process - even during the initial construction.
FloridaOrange
Plumbing Designer
SW Florida
STyler, are you allowed to wet vent??
What you describe is not the big deal it seems that it's being made into.
STyler
Rock Hill, SC
I can do whatever I want in the barn. I just want it to work without issues down the road (and before I finish off everything and a solution becomes even more costly).
EDIT> I'm going to head down to the barn now and take some pics in case it will help.
FloridaOrange
Plumbing Designer
SW Florida
If it's wet vented correctly you won't have any issues. Wet venting is done all the time, has been accepted by most codes going back 20+ years. All of the houses I've lived in in Florida have been wet vented and I've never had a problem. I've never heard of a problem unless it was installed incorrectly.
STyler
Rock Hill, SC
If I "wet vent", is there anything I need to accommodate when framing? I'd like to bring a plumber in after I have everything framed, but I don't want a bunch of rework because of it.
FloridaOrange
Plumbing Designer
SW Florida
If it is wet vented your pipe coming up for the sink should be a 2" which you would carry the 2" vent up from the tee and out through the roof.
Master Plumber Mark
www.weilhammerplumbing.com
that willl work
that is probably what the original master plumber had intended to do..... its probably all ok...
FloridaOrange
Plumbing Designer
SW Florida
We can't see through the floor to know the order of the piping but if it is installed correctly the horizontal branch under the floor becomes the vented line, therefor you wouldn't need to individually vent the water closet and shower because they would already be vented (by the horizontal line).
