Wiring light switches.
Piperca
California
I am wiring four switches from one source, which will control four separate locations. Since I am feeding all four switches from the same source, is there anything wrong with wiring the switches from the source in this manner?
Obviously, this is just the hot and ground, all neutrals would be tied together and the black to each location would be connected to the switch, also. I'm just trying to reduce the amount of clutter in the box.
Alectrician
DIY Senior Member
That is often done to reduce clutter.
The only issue comes when you want to replace a switch....maybe install a dimmer, and there isn't enough wire to work with.
It is fine though.
Piperca
California
Thanks for the insight, guys. I will never change these switches ... unless one fails, of course.
wires
It's the way I do it with maybe a little more "loop" to the grounds to allow a bit more flexibility in spacing the switches to fit the wall plate..
