Thread: What is a syphon jet flush toilet?
    DIY Junior Member nelson84's Avatar
    Sep 2009
    Canada
    Default What is a syphon jet flush toilet?
    What is a syphon jet flush toilet? I am putting in a new toilet on the fourth floor of my house and the water pressure is not that great. Does a syphon jet flush toilet need alot of pressure or is it like a regular toilet that is a gravity fed toilet?
    A siphon jet bowl has a jet at the front that water comes from, and it starts the siphon.
    Old style bowls only wash down from the upper rim holes.
    Sep 2009
    Canada
    So I don't have to worry about having strong water pressure? Its not like a public restroon toilet?
    So I don't have to worry about having strong water pressure? Its not like a public restroom toilet?
    Most toilets for home use have a tank combined with the siphon jet.
    It can either be a gravity tank, which works with any pressure over 20 PSI
    or a pressure assist, they would need more pressure to work well.
    Commercial valves rely on large pipes to each toilet.
    You will never be able to use those in a home successfully without adding a storage tank behind the wall.
