Results 1 to 2 of 2
Thread: Copper Fitting Leaking on pressure vacuum breaker-update info
    DIY Member vaman's Avatar
    Jul 2009
    NJ
    Default Copper Fitting Leaking on pressure vacuum breaker-update info
    When I posted the question about the female copper fitting leaking on the supply line to the pressure vacuum breaker I left out some relevant info. The leak is very slow;I guess about 1 drop a minute but it is definitely leaking. When I was removing the old female pvc fitting I put a small nick in the outermost 1 or 2 threads.
    Is there some product I can use to sort of patch the area on the thread or am I looking at desoldering this fitting? Teflon joint compound helped alot but the leak is still there.Thanks again for your help
    Default Prv
    I do not think I have ever seen any vacuum breaker that fastened to a female thread. But, because of the way threads work usint a proper sealant and tightening it completely willl usually repair an minor damage to the threads, (major damage will usually prevent the two from even engaging).
