Thread: HELP-Replacing Closet Flange/Lead Soil Pipe - suggestions
    Default HELP-Replacing Closet Flange/Lead Soil Pipe - suggestions
    Considering changing current cast iron closet flange/lead soil pipe in a 35+ yr. old house. Would perhaps like to use ABS or PVC and connect to 3" copper soil pipe in basement. Attached are pictures showing closet flange in 1st floor bathroom and showing lead riser/soil pipe and copper connections below (in basement). Have good access to pipes below, which should help.
    Lead riser goes into a solid copper elbow, which goes into 3" copper soil pipe.
    How would you recommend replacing this?
    ABS, PVC, or Cast Iron Assy?
    Was thinking of using 3" ABS flange/elbow/piping and getting threaded adapter that goes from 3" ABS to 3" copper. Comments? Problems?
    Or, more simply a 3" rubber Fernco?
    Looking at the picture, does anyone see any problems?
    Any advice anyone could provide would be GREATLY appreciated.
    Terry, any suggestions on how to replace and what components to use? Thanks in advance for your time.
    Plumber plumber1's Avatar
    Aug 2005
    Florida
    Default replace?
    Why do you want to replace anything.
    In the picture it looks like a good material......
    It looks good to me too.
