Thread: PROS and CONS?
    DIY Junior Member Criddle's Avatar
    Sep 2009
    Idaho
    Default PROS and CONS?
    What are the pros and cons of having a pump that can pump more than you need?
    I have a pump now that is cycling not more than every 30 sec. when the sprinkler is on and it seems way to often. I was considering a 13GS20 gould pump.
    I also seem to have very low pressure. I can only run one sprinkler at a time.
    To learn all about it, start at the link below or buy a CSV (Cycle Stop Valve) and protect whatever pump you have now or later.
    http://www.irrigationtutorials.com/pump.htm
    Jul 2008
    S. Maine
    About a minute or so between cycles would be better. Need more information though to be able to give you an answer. Such as, what do you have for a tank. What is the pressure switch set at, and anything else you might have on the well itself. Just remember that sprinklers are typically pretty high demand.
